October 24, 20232 yr I have a Shoto SDA10 48100 15S lithium battery It is working perfectly fine but it has one major problem, the charge current doesn't go higher than 10A, while it can be charged with much higher amps, any solution? C.V = 53.2v ( also tried 54.5 ) The charging parameter on my inverter is 40A or 30A ( Growatt SPF 3500 ES )
October 26, 20232 yr That seems strange, usually the BMS will have current limiting to 10A when it gets full, usually above 90% so it can slowly balance the cells. I'm not very familiar with your inverter, but it could possibly be the wrong lithium battery selection if you have comms working with the battery.
