October 6, 20187 yr Hi PF, My load is both AC and DC.Can I share the DB? Iow have both AC and DC components on the same din rail to save costs and space? Thanks Edited October 6, 20187 yr by flamegrilled
October 6, 20187 yr No, don't do it. You won't get a COC for it, and you'll probably run into some EMI (Electromagnetic Interference) problems.
October 6, 20187 yr Keep an eye on ACDC monthly specials. I bought this surface mounted one for R475 with the breakers. (excluding change over) All my plugs and lights are split to the new one.
October 6, 20187 yr Author 2 hours ago, SilverNodashi said: You won't get a COC for it Thanks @SilverNodashiI did split it . I bought another small one just for the DC breaker and its load(element) Thank you @GVC I have a few CB's I can still use in that db for lighter load circuits .
