November 29, 20232 yr Author Can anyone help me. What is the 105 value next to the state of charge percentage that is on 53%. It started on 90 a few days ago and keep on rising. My state of health is 100%.This is an Esener 5kw 51 v battery with an Esener 5.5v inverter.
November 29, 20232 yr Just an observation 53.00v is actually close to 80%soc 50%soc= 51.2v or 3.2v/cell these readouts based on voltage is normally not accurate. Do you have access to the bms via monotoring software. Edited November 29, 20232 yr by TaliaB
November 29, 20232 yr Author Nope wifi extender is not communicating with the esener inverter. Might be the number of cycles as I am on a setting uses the battery during the night so that it can be charged during the day again by the solar panels.
November 30, 20232 yr 13 hours ago, TaliaB said: Just an observation 53.00v is actually close to 80%soc 50%soc= 51.2v or 3.2v/cell these readouts based on voltage is normally not accurate. Do you have access to the bms via monotoring software. There are NMC cells inside, will have a different voltage curve compared to LFP.
November 30, 20232 yr It may be the display is showing the SOC and that 105 next to it could possibly be the max capacity of the battery, i.e 105Ah?
