New problem in our area . 3rd time this week the water pressure is very low . Because of the low pressure the water does not get to the flat plate collecter . The water circulation pump switches on when water difference is more than 7 degrees between geyser and collector and keeps on running because no water is circulating . What worries me is that the pump will get damage and the collector heat up to 115 C . I switch of the system to protect the pump . This causes the geyser to cool down and when the pressure is back the water is cold . What is the best solution . Do have a 0.4 kW pump and Eco water tanks .
The pressure pump is a good idea . I would like it to be from my rainwater system or secondary  source because it also happens often that there is no water . Would like some ideas stopcock or one way valves to get it running . Went of grid with the Axpert to keep the electric worker alive on the pole , can't pump my dirty water into the counsel water. ??
2 hours ago, Javi Martínez said:
including a pressure sensor
Most of the pumps sold around here will generally come with the extra little diaphragm protection unit on top, which usually already includes a one-way valve and a pressure switch. So that's a solved problem that you can buy in the hardware store.
Separating the supplies is a bit more complex. The proper valve you're supposed to use, one with what is called an "air gap", is quite expensive.
Ok, if the pump includes It, it's easier.
They sell little pump kits, at least where I live (we're in the middle of a big drought, worst in about 300 years) for connecting tanks and things to your house. It usually comes with one of these:
Normally you also want one of those pressure tank bladder things so the pump doesn't turn on and off too frequently.
Thanks for the info Plonkster . We have a Afgri shop in town that stock pumps and water equipment . Waiting for a filter from Eco depot , then I can start to instal . The geyser wise system can operate with a 12 volt DC pump or 220 volt AC . I have a 12 volt pump installed . There is a 5 Amp 220 volt pump connecting point in the connection box . Will check tomorrow if I can use both at the same time . If I can it will be an easy electric installation . No water for the last few hours and won't have water tomorrow .
Hi Chris
I have a similar setup but have not experienced this problem.  I think this is due to having a one-way valve installed on the cold-water inlet to the Geyser.
The circulation pump gets the cooler water from the "bottom" of the geyser and pumps it through the collector and then back into the geyser - so should only fail if the geyser is almost empty?  It may also be worth checking that the mesh strainer/filter is not partly blocked - my filter needs to be cleaned every few months.
Hi Nigel the system is fitted with one way valves on the hot and cold lines . There is also loops installed if a valve should fail .The system works fine as long as it is full of water . If a tap is opened while the pressure is low and some of the water in the pipes run out the pump keeps on running but does not circulate water . As soon as there is pressure and the system is full it is fine again .Thanks for your replie . The rainwater supply is now fitted , just waiting for the filter and pressure control . The joys of a small town .Wait for everyting
