Infinisolar Current and Parallel Cables
Hello
I hope you are well. I have bought a 2nd Infinisolar inverter, and I am short one pair of parallel and current cables to allow the two inverters to work in parallel. Does anyone know where I could source these cables from?
Regards,
Simon
20 minutes ago, Simon Murrell said:
Hello
Regards,
Simon
Do you have a model that can be used in parallel. Some cannot and each must be wired to their own load on the back up side.
I would think that if an inverter comes with a parallel board, it would also come with a set of cables.
You should be able to buy a kit from your supplier that has one board and one of each cable. You might be able to get just the cables from them. I don't think that they are particularly expensive, so you could just buy a new kit, and have a spare board.
Both models which I have are Infinisolar 15kw inverters. They just branded RCT and other Mecer. I am looking for a 2nd set of cables. They can be run in parallel up to 6 units if I am not mistaken.
