Sunsynk inverter question.
I have a Sunsynk 5.5 kw inverter. How to I set so there is zero export to grid. If I tick "the limit to load" only will the solar still charge battery during an outage? Thanks in advance.IMG_3088.thumb.jpg.de9c4491fd6976359f9dd6725699b94a.jpg
Un-Check Solar Export then it will be the same as mine which has been working great for almost 3 years now :)
Do not check Limit to Load Only unless you do not want your non-essentials powered.
Yes if there is load-shedding the batteries will still charge if there is enough power for the loads and any left over will go into the batteries.
Is there a particular reason you Have the inverter limited to 500W ?
Edited by WannabeSolarSparky
To limit export. It doesnt stop it.
