December 31, 20232 yr It appears if both my switches has stopped recording usage data today and the first day on record of the devices are 31 Dec 2022. Does it only hold 12 months data or could something have gone wrong in it having to erase old data and replace with new data for the months/days? It still shows the actual usage real time, but not total usage for the day. Any ideas?
December 31, 20232 yr 2 hours ago, PearlJam said: It appears if both my switches has stopped recording usage data today and the first day on record of the devices are 31 Dec 2022. Does it only hold 12 months data or could something have gone wrong in it having to erase old data and replace with new data for the months/days? It still shows the actual usage real time, but not total usage for the day. Any ideas? Check if you have History checked on the bottom of the Consumption selection. Under history my smart switch of a different make only holds values for the past 100 days. It deletes on a 1st in 1st out basis. It does however record the total under the Real time tab at the bottom of the Consumption screen. My start date is July 2020. Did you perhaps update firmware recently in the APP. Edited December 31, 20232 yr by Scorp007
January 1, 20242 yr Author Thanks. The CBI app does not have a "history" check box also no firmware update since I got the switches. However, last night at some stage all of a sudden the total usage was updated. Very strange.
January 1, 20242 yr 5 minutes ago, PearlJam said: Thanks. The CBI app does not have a "history" check box also no firmware update since I got the switches. However, last night at some stage all of a sudden the total usage was updated. Very strange. Good that it is working. I don't have the CBI but thought you will have the same features/settings as some other units.
January 2, 20242 yr On 2024/01/01 at 1:40 PM, Scorp007 said: Good that it is working. I don't have the CBI but thought you will have the same features/settings as some other units. The device manufacturer exposes settings and features as options unfortunately. I have a few brands of different devices and the capabilities and even look of them in Smartlife varies. Most irritatingly for me the "Resume last state after power restored" isn't even available in all of them,others don't have current sensing and/or history
January 2, 20242 yr 16 minutes ago, PsyWulf said: The device manufacturer exposes settings and features as options unfortunately. I have a few brands of different devices and the capabilities and even look of them in Smartlife varies. Most irritatingly for me the "Resume last state after power restored" isn't even available in all of them,others don't have current sensing and/or history The Sonoff does have resume last state.......
January 2, 20242 yr 1 hour ago, Scorp007 said: The Sonoff does have resume last state....... Just using an example - don't expect every device of the same type to have the same features
January 2, 20242 yr 52 minutes ago, PsyWulf said: Just using an example - don't expect every device of the same type to have the same features My mistake. Sorry.
