December 12, 20187 yr Good day, Can anyone supply me with an Imeon IMA-BOX or tell me where I can buy it? I contacted IMEON about it, and consequently a place in Bloemfontein contacted me with a quote of: R5050 Seems a bit much.
December 12, 20187 yr In the long run it will actually be cheaper to buy an new inverter that can connect to Pylontech easily, than carrying on with an Imeon supplied by the Bloem crowd!
February 23, 20206 yr On 2018/12/12 at 5:50 PM, Chris-R said: In the long run it will actually be cheaper to buy an new inverter that can connect to Pylontech easily, than carrying on with an Imeon supplied by the Bloem crowd! Which inverter would you recommend replacing an Imeon 3.6 with that does the same as the imeon? I'm looking at getting lithium batteries and also need to buy the ima-box for my imeon to work with them
