January 25, 20242 yr Hi all, I've just installed a 5th pylontech us5000 to my system comprising 3 x us2000, 1 x us3000c, after balancing them I turned everything back on but my luxpower 3.6 hybrid inverter doesn't charge or discharge the batteries or recognise any solar production, it seems the DC part of the inverter has stopped working, the inverter sees the import from the grid but nothing else. Any help would be much appreciated
January 25, 20242 yr 30 minutes ago, ohdaesu said: Hi all, I've just installed a 5th pylontech us5000 to my system comprising 3 x us2000, 1 x us3000c, after balancing them I turned everything back on but my luxpower 3.6 hybrid inverter doesn't charge or discharge the batteries or recognise any solar production, it seems the DC part of the inverter has stopped working, the inverter sees the import from the grid but nothing else. Any help would be much appreciated What happens when you switch the grid off?
January 27, 20242 yr The us2000 with out a C can only do 1 master and 7 slaves the us3000C and up5000 can do 1 master and 15 slaves
