Don't see entities and devices after connecting HA to SA
I've followed the instructions on https://solar-assistant.io/help/home-assistant/setup
When I test the mqtt broker on my SolarAssistant using mosquitto_sub I do see:
solar_assistant/inverter_1/pv_voltage_1/state 288.5
solar_assistant/inverter_1/pv_voltage_2/state 299.5
solar_assistant/inverter_1/pv_power_1/state 2447
solar_assistant/inverter_1/pv_current_3/state 9.4
solar_assistant/inverter_1/device_mode/state Hybrid
solar_assistant/inverter_1/grid_voltage/state 238.3
solar_assistant/inverter_1/generator_power/state 0
solar_assistant/inverter_1/ac_output_frequency/state 50.13
solar_assistant/inverter_1/grid_power_ld/state -2352
solar_assistant/inverter_1/load_power_non-essential/state -52
solar_assistant/inverter_1/pv_voltage_3/state 245.5
solar_assistant/inverter_1/ac_output_voltage/state 237.9
solar_assistant/inverter_1/load_power/state 4524
solar_assistant/inverter_1/pv_power_2/state 2532
solar_assistant/total/battery_power/state 0
solar_assistant/total/battery_state_of_charge/state 100
solar_assistant/total/battery_temperature/state 29.3
But on HomeAssistant under devices I only see 1 device and 1 entity (Deye/SunSynk/Sol-Ark Response). No other sensors or entities are loading.
Can anyone point me in the right direction to fix this?
