March 9, 20242 yr Herewith dashboard of my system, last 2 days. 2 X 5000 ES Growatt inverters + 12 X 410 W CSun solar panels. Edited March 9, 20242 yr by Antonio de Sa
March 19, 20242 yr On 2024/03/15 at 10:01 PM, MSkermit said: That dashboard looks great. What are you using? That's Grafana speaking to some sort of DB in the background. Perhaps Home Assistant's DB.
March 19, 20242 yr Author 40 minutes ago, PilgrimToHyperion said: That's Grafana speaking to some sort of DB in the background. Perhaps Home Assistant's DB. Yes, Grafana as a display, information coming directly from the inverters and the LBSA battery Seplos BMS using Modbus protocol via Rpi.
April 1, 20242 yr I am jumping in on this related topic. 🤔 March turned out a good month and my 2nd best in a few years. PVw=2.5 kW. Total yield 329 kWh. System was off for 2 days. Lower LS helped a lot as my main system does not work when the grid is off. Then my back up Axpert must earn it's keep. Normally only cycle batteries during LS. Shadows are getting longer and yield is slowly coming down. Some panels affected after 12h30. I used less than 2 kWh per day for the month.
April 1, 20242 yr Author 17 minutes ago, Scorp007 said: I am jumping in on this related topic. 🤔 March turned out a good month and my 2nd best in a few years. PVw=2.5 kW. Total yield 329 kWh. System was off for 2 days. Lower LS helped a lot as my main system does not work when the grid is off. Then my back up Axpert must earn it's keep. Normally only cycle batteries during LS. Shadows are getting longer and yield is slowly coming down. Some panels affected after 12h30. I used less than 2 kWh per day for the month. March 2024 actually worst mounth since I started monitoring my production/consumption. herewith March dashboard. Edited April 1, 20242 yr by Antonio de Sa
