Axpert vm 3 kva Plus is not detecting solar ( PV )
15 hours ago, mazo78 said:
please any body tel me whare is fault in mppt board ??
If this is equivalent to the model you have:
http://voltronicpower.com/en-US/Product/Detail/Axpert-VM-II-3KVA-5KVA
then you need at least 120 VDC to start the MPPT. It might need even higher voltage to get it started. Your video showed less than 60 V, presumably across the PV inputs.
Thanx but this mppt controller is 24 volt To 120 volt sported
Dang those inverter part numbers.
Unfortunately, the service manuals don't seem to be any help with troubleshooting the SCCs. I think all you can do is to check the MOSFETs and their drivers. Hopefully there will be enough drivers with similar components that you can compare one to the other. It will probably an interleaved configuration, like this:
That's about all I can find in the service manuals, sorry.
