April 21, 20242 yr Random combination, I know. Trying to help friends get the BMS between these two running, not sure if even possible. Everything worked fine without BMS until a multi-day power failure recently, now inverter does not want to charge battery anymore. Have searched webs without luck for the correct cable pinout, would apprecate help if someone knows.
