May 12, 20242 yr Hi, What is the best mounting hardware to fix an 8kw inverter (30kg) to a brick wall? The mounting hardware supplied with the inverter doesn't look to be strong enough
May 12, 20242 yr 8mm x 100mm Stainless steel coach bolts, washer and appropriate Fisher plugs. Suggest 2 plugs per hole 'The length provides the maximum strength for that weight
