LVTOPSUN 4.8KWH Lithium Battery LV48100 LifePo4
Good Morning!
I have 4 of these batteries (400A 19.2Kw) and my Dye 5KV inverter battery settings are this:
  • Max discharge current: 100A
  • MAx charge current: 80A
  • Battery float charge voltage: 54.4 V
  • Battery absorption charge voltage: 55 V
  • Battery equalization charge voltage: 57.6 V
I am using Solar Assistant for management and monitoring...
Best Regards
Jean
Edited by Jean Vos
41 minutes ago, Jean Vos said:
Good Morning!
Best Regards
Jean
Nice conservative settings, those batteries should behave and last a long time :)
  • 7 months later...
  • 1 year later...
  • 3 months later...
Coming late, but these batteries have 15 cells, their operating range is maximum 52.65V. Your proposed setting is valid for a battery with 16 cells.
[Side note]: trying to find firmware update for these batteries, having three different versions 1.05, 1.07 and 1.09, they don't like paired BMS controlled master/slave configuration and they don't have a physical DIP switches for setting up ID. Perhaps it is related to the firmware difference. Anyone?
Edited by sajunky
