Solar man logger offline
Hi,
In solar man my logger says offline, do I need an external logger of my inverter is WiFi compatible?
When I click on networking i cannot to the inverter AP but is doesn’t connect and show stats? What am I doing wrong?
On 2024/06/14 at 10:36 PM, Raiden2912 said:
Hi,
Your inverter isn't a Deye inverter I assume. All deye inverters have external loggers, solarman is deyes software. If you have a voltronic inverter (which I assume you do) then you can't use solarman. No benefit in doing so either since you have solar assistant.
The voltronics use the 'watch power' app which is hopeless.
Edited by abd7
  • 7 months later...
Hi my inverex inverter of 12kva (06+06) in parallel but in solarman app only one showing online and the other one is showing ofgline kindly let me know the solution
