March 5, 20197 yr Morning, Is there anybody out there that can give me guidance on the above-mentioned. The pre paid meter is running now double speed😡 although I installed the Export power manager with CT installed. Â
March 5, 20197 yr 37 minutes ago, Ronnie_V said: double speed😡 Turn the CT around. At the risk of ruining a short answer that might be right... you know like telling someone to change their air filter when they complain of bad fuel economy... (you see them 2 days later and they are like: how did you know!?) if the meter is really running double speed, it might be seeing the wrong direction and running flat-out to cancel out a load... which is actually itself exporting).
March 5, 20197 yr Author Tx Plonster, sneaked off and tried it. The moment I turn the ct around the epm does not see the ct anymore. These units seems to be of good quality but after sales service non existing. I am also unsure about the feedback setting, manual does not give values.
July 11, 20197 yr Doesn't sound good Ronnie ,give me a shout on whatsapp or email and i will assist with your setup 0828517568 /Â [email protected] Â
