Beginner seeking advice please on small solar setups for LAN wireless
Hi all,
I have very limited knowledge of solar and would really appreciate advice as to components and where to source them.
I have a local IT business and have been asked to install network on a farm. Some of the points are remote with no mains power, so need to be solar. I really didn't think it would be an issue as small panels/batteries/controllers now seem to be commonly included with cameras and lights. However....
Power needed is max around 20W with, say, a 3 day reserve. The units I use need between 12 and 30V but, as they can become unstable at the lower end, I like to use around 18 to 24V which could either come from 2 off 12V batteries or a DC/DC boost.
Ideally, I'd like to obtain a complete package of panel, mountings, box, charge controller and battery.
Thanks for any help,
Adam
10 hours ago, AdLew said:
Hi all,
Adam
A 3 day reserve would mean some battery power of 1440Wh. If one takes the recharge from PV one could get a system using 2x 12V 50 Ah lithium batteries. Even with low irradiance per day the size of the panel will be the main variable. A panel of 425W should take care of some of the worst 3 day rain/heavy cloud I guess.
It seems like a package will have to be made up to suit the application. I would use a good MPPT instead of cheaper solar charge controller and prefer one with blue tooth connectivity.
  • 5 weeks later...
Please Be warned it happened on my hobby system.
If you use a cheap 12/24v charge controller, the V out gets determined by the battery connected to the controller and the default output V is 24V.
That means if you run a 12v battery with a 12v load and the battery gets disconnected, the controller output V will default to 24v. And then the magic smoke comes out of the 12v device which now gets 24v and goes poof.  Eish
I don't know if this happens to all 12/24v controllers.
Edited by Vaal
