My batteries are not charging
My batteries went under voltage cut-off, and my Growatt SPF 5000ES stopped charging them. I changed the settings from LI to US2, and it started charging, moving from 24% to 25%. However, now it’s stuck at 25% and won’t go higher. What can I do? I am very new to solar
If you changed from LI to USER  then you have to  setup the bulk and float parameters to suit your batterys . So more info on lithium installed or cells used will be helpful
Edited by GMAC
How to setup bulk and float parameters boss? Can you help little me by providing the information?
