Brand New Pylontech US3000C SysError / System Error 4096, ALM LED on
Hi,
I am new to the Forum, and subscribbed to ask for your valued help on the following issue I am facing.
I bought 2 US3000C to extend my single phase victron ess (multiplus II) setup, one of the modules works properly, the other is detected as blocking charge/discharge because of System Internal Error.
Using BatteryView I could fetch the details from the module and there is no evidence of any over/under voltage or temperature issue that would block charging.
The Basic State is SysError, and the System Error Reads 4096.
Is there anything else to check / or I can do apart from returning it?
Edited by nibbler79
The question is less about the setup than the strange pylontech behaviour of a brand new us3000c - never connected or charged.
Box might be DOA - but the retailer wants me to send it back to the german distribution to get it checked. and I wanted to know upfront if it is clearly a warranty case.
My setup is 2x2 US3000C connected to a victron multiplus II via single phase for UPS Backup Power and ESS Usage.
The US3000C are connected via victron lynx as paralleled pairs.
Thing is the described US3000C was not even hooked up, and was in state ALM Led on, so I tried to charge it, but no current bigger than 30mA flows. Thats why I hooked up batterview, and it seems that the pack does have 40% SOC and the failure is not due to undervoltage.
Do you know what errorcode 4096 stands for?
Edited by nibbler79
My setup is 2x2 US3000C connected to a victron multiplus II via single phase for UPS Backup Power abd ESS Usage.
br
markus
So many people come on here expecting answers but do not give details of their system.
You have now given us more of an idea.
You say you are extending yours system and have not given any idea as to what you really have. You ask for firmware for your existing batteries in another thread but we don't know how many- you may have reached the max number, have older types in their as well.
What is the production date on the battery?
Oh, sorry. I understand the point.
The new ones are both from 20240812 and the older ones both from 20221027
I put this in the other post as well.
If there are any more things I can pull from the console or any other details I can share let me know. I did not know what is needed.
Thank you so far for your patience with me, and for your answers :)
Thanks. I'm still none the wiser as to how many batteries you have though. :) Edit- I see that is in the other thread and here after careful reading..
Your BatteryView screen shots don't look to be of your new battery!! The firmware is 2.8 and release date is 2022.  Even if If Pylontech have gone back to manufacturing the old chip batteries again, which I very much doubt, their latest firmware is 2.9. You want to pull the data from the full pack.
(I'm not certain on this but it looks as if you are using the HV version of battery view- I've not tried it on LV batteries and I don't know if it's specifically for the HV.)
Have you got a new battery as the master?
Edited by Tinbum
sorry again, i just realize the console logs i pulled and where i took the version information from are older than the screenshots i made.
in total i got 4 us3000c.
the one on the screenshot is the problematic one. i pulled the latest firmware from effekta (the distributor) and flashed that one, to see if a firmware update resets the situation.
it did not, problem persists.
so one of the new blocks is on v2.8 at the moment and not 3.0 anymore.
anyhow - which version would ve recommended for the board i have? I would flash all 4 to the same, if you can supply the firmware link.
I'm confused. Having 2 threads doesn't help either.
V2.8 would be for an old chip battery not a new one. (Unless pylontech have changed something).
the effekta download included a flasher that autoselects the right file according to the documentation of the flasher.
(using the zipped file)
the serial starts with Y240812C1001
That seems to suggest its an old chip battery but you say it's brand new so perhaps pylontech have gone back to the old chip.
Have you got the other new battery as the master?
When did you downgrade the firmware from 3.0 to 2.8?
at the moment i am running the stack with 3 (2 old / 1 new) one of the old is  master and its working properly without errors.
the 4th though cannot be added. its not getting into a state of running even as standalone and there is no voltage output at all.
meanwhile i was playing a bit with the pylon debug console and found:
pylon_debug>tpv
socic volt: 0
bmic volt: 49214
Bq34z100 Total volt error > 30 mV, calibrate it  Test result:fail
I fear there is some hw issue.
pylon_debug>tpv
socic volt: 0
bmic volt: 49214
You should always have the newest battery as master. Has that still got the original firmware on it though? (I've not seen 3.0 available anywhere).
You said they had offered to take it back- that is what I would do.
Did they request that you change the firmware on it or have you done that off your own back?
Edited by Tinbum
I did the firmware change. I misinterpreted that it is newer, while it actually is older than what was on there initialy.
The retailer I bought from was telling me to return it to effekta on my cost. I was also warned that I would have to pay for troubleshooting if I return it without a need. I wanted to be sure it is not revivable without sending it through the land once more, and didnt want to risk 400 bucks which is half of the devices  price.
If they would have offered to take it back right away I would not have bothered to tinker with it.
Might habe brought me into a situation now that is leaving me with an expensive paperweight.
I'm really struggling with this as your not answering the questions that I'm asking.
Please go back and answer all the questions and give us a detailed description of what you have done, when and in what order and how.
Edited by Tinbum
Ok, sorry.
Lets start over, I'll try to be as precise as possible. - I know I confused you with the wrong version information on the second thread.
I am running the Victron Setup since 07/2023 with the 2 "old" US3000C.
So one Victron Multiplus II with Cerbo GX and Lynx Distribution.
The two Batteries connected with one uplink kit cable set to the lynx.
Batteries paralelled with the shorty cables and connecting positve uplink from the lynx on one US3000C and negative uplink on the other US3000C.
The setup was running since that day and night without any issues or errors.
The Usecase is single phase ESS and critical load UPS for the IT Equipment and Fridge.
There is no DC Charging from PV on the setup - I have 5 microinverters from Hoymiles that are AC coupled to the grid.  (4xhm1500 on the roof, and 1xhm800 on the balcony)
End of October I ordered 2 US3000C at a german reseller for Extending Capacity.
I ordered one additional Uplink Kit as well, since I wanted to hook it up like the other one paralelled to lynx.
I received goods about two weeks later.
When unwrapping the two US3000Cs I switched them on and started BMS to see if they come up properly.
One did (green led blinking, SOC about 50%), the other one did not show any Leds first, and after cycling again went into "ALM LED on" state.
None of my others ever did that, so reading the manual I came to the conclusion that LED on, no beep means undervoltage.
Manual states to charge until LED goes off.
So I measured with a Voltmeter, and did not see any voltage at all. Hooking them up to the other block without Can Connection to Balance it, or trying to charge with Bench Power Supply at 53 Volts / Limit 200mA did not Change the condition. The US3000C was not accepting any charge.
At that point I was contacting the reseller, asking for replacement.
I was asked to send the device to effekta directly, shipping on me. I was also warned that in addition to shipping the cost for checking at effekta will also be in my charge if they conclude this is no warranty issue.  No other instructions where given at all. Asking for effekta contact, I did not receive anything.
Checking shipping cost for dangerous goods I figured that the total cost to get this fixed might be quite high - leading to further investigation on my own.
So next I was getting a proper USB/RS232 Adapter and hooked up the terminal.
I used the console to check for errors. - but appart from the syserror I did not see any problem with cell voltage or temperature.
I also took some console logs. (the ones I used to copy/paste the wrong version number from later - SORRY!)
Next I was looking for instructions from Effekta.
I found the firmware pack (labeled as latest) on the effekta homepage, and figured a fw upgrade might resolve the issues I am seeing.
Unfortunately I missinterpreted the version number as newer and downgraded the US3000C to v2.8 without any change to the behaviour - LED ON, no Voltage on the
Pack.
Situation was worse now - having a older version on the device, not having fixed the issue.
To make use of the new working US3000C I hooked this one up to the stack to balance, and took it into production after that. Now working without problem since a day (~ 1 cycle, balance of the 3 packs is quite good already) - Still the CAN Master being one of the old ones because of CAN Cable length being too short to reach the new one at the bottom in the rack.
Later that day I found your forum, and read about batteryview. Thinking about additional insights and not beeing in possession of a working copy of batteryview I registered here, and after getting my account enabled used batteryview to produce the screenshots used in the post.
I created the post already showing downgraded v2.8 but did not mention the downgrade unfortunately.
In parallel I found the other post talking about Firmware from June.
Thats why I asked if anyone has a recent firmware, at best the one I already have on the new properly running US3000C or even a newer one if existing, planing to upgrade all to that, if anyone can share it. I forgot to mention that I meanwhile downgraded the module to v2.8 here as well.
This led to all the confusion I produced :(
Meanwhile I am quite out of ideas what I still can try to recover the not working US3000C - so if there is anything I would be glad to get a hint.
So status quo is:
4 US3000C, 3 in proper production, 1 in the ALM state being separated from the stack and sitting on my electronics workbench.  (Still closed since I dont want to void warranty)
Versions are:
Older ones:
Production: 20221027
Board: NF4.E2
Board Version: V10R04
Main Soft Version B69.13.1.0
Soft Version 1.7
Boot version 1.0
Comm version 2.0
Release Date:220825
newer working one:
Production: 20240812
Board: not showing
Main Soft Version B68.8.0.0
Soft Version 3.0
Boot version 2.1
Comm version 2.0
Release Date:240725
newer errorneous one:
Board: not showing
Main Soft Version  B68.5.0.0
Soft Version 2.8
Boot version 2.1
Comm version 2.0
Release Date: 220902
Using MultiSIBControl I figured that it gives pylon_debug access, so I had a look at some command outputs.
I am curious if this is the problem - it seems that the Pack Voltage according to bmic is 49218 while socic is showing 0 volts.
See outputs collected below.
pylon_debug>data
Item Index      : 3
Time            : 24-11-17 23:05:43
Voltage         : 49218       mV
Current         : 0           mA
Temperature     : 23100       mC
Percent         : 39          %
Total Coulomb   : 74000       mAH
Max Voltage     : 54000       mV
Base State      : SysError
Volt. State     : Normal
Curr. State     : Normal
Tempr. State    : Normal
Coul. Status    : Normal
Power Events    : 0x10000000 SYSERR
Bat Events      : 0x0
Bat Protect ENA : BOV BHV BLV BUV BSLP CBOT CBHT CBLT CBUT DBOT DBHT DBLT DBUT
Pwr Protect ENA : POV PHV PLV PUV PSLP POT PHT COC2 COC COCA DOCA DOC DOC2 SC LCOUL
System Fault    : 0x1000
Battery  Volt     Curr     Tempr    Base State   Volt. State  Curr. State  Temp. State  Coulomb
0        3281     0        21000    Idle         Normal       Normal       Normal       39%
1        3281     0        21000    Idle         Normal       Normal       Normal       39%
2        3281     0        21000    Idle         Normal       Normal       Normal       39%
3        3281     0        21000    Idle         Normal       Normal       Normal       39%
4        3281     0        21000    Idle         Normal       Normal       Normal       39%
5        3281     0        21000    Idle         Normal       Normal       Normal       39%
6        3281     0        21000    Idle         Normal       Normal       Normal       39%
7        3281     0        21000    Idle         Normal       Normal       Normal       39%
8        3281     0        21000    Idle         Normal       Normal       Normal       39%
9        3281     0        21000    Idle         Normal       Normal       Normal       39%
10       3282     0        21000    Idle         Normal       Normal       Normal       39%
11       3282     0        21000    Idle         Normal       Normal       Normal       39%
12       3282     0        21000    Idle         Normal       Normal       Normal       39%
13       3281     0        21000    Idle         Normal       Normal       Normal       39%
14       3281     0        21000    Idle         Normal       Normal       Normal       39%
Command completed successfully
Remote command:
pylon_debug>socd
BQ34z100 Data
Pack Volt           : 100          mv
Pack Current        : 400          mA
state of charge     : 100          %
Remain Capacity     : 400          mAH
pylon_debug>tsoc
Bq34z100 work abnormal, reset
Test result:fail
pylon_debug>soct
 Chemistry id: 0
 Bq34z100 Ra Table
 |Pos  |R_a0    |R_a0x   |
 |flag |0       |0       |
 |0    |0       |0       |
 |1    |0       |0       |
 |2    |0       |0       |
 |3    |0       |0       |
 |4    |0       |0       |
 |5    |0       |0       |
 |6    |0       |0       |
 |7    |0       |0       |
 |8    |0       |0       |
 |9    |0       |0       |
 |10   |0       |0       |
 |11   |0       |0       |
 |12   |0       |0       |
 |13   |0       |0       |
 |14   |0       |0       |
pylon_debug>tpv
 socic volt: 0
 bmic volt: 49197
Test result:fail
Thanks, That's great. :)
Firstly it seems as though Pylontech have maybe gone back to the old chip in their new batteries to confuse us all again.
In another thread we suspect that Pylontech have now made it a requirement that the battery will not supply power unless it has CAN communication. So it's possible that if you tried charging it with the 3.0 firmware installed it may have that feature so that's why it showed no voltage and accepted no charge.
I'm slightly surprised their was no warning when you downgraded the firmware, though I have never downgraded so don't know if their is one. The fact you could down grade is great if they have introduced a CAN heartbeat requirement, though I myself would never use one without CAN.
I uploaded 2.9 to the files section the other day so you could try that. I've not used it yet though and they never give an update log.
You can also do a reset in BatteryView.
You could do 2 other things-
Ask Pylontech for the 3.0 firmware (if they send it could you upload it here).
Go to Pylontech direct.
My thoughts are;
It does seem as if their is a problem with the battery, especially as the other works ok. All the voltages look fine as is its SOC.
I'd go back to the supplier and request they collect it from you and threaten that if they don't' and you used a credit card' go to your bank and request a charge back.
My thoughts are;
thank you for the long feedback.
so my socic measuring 0 is not of concern? i also tried to turn on cfet as well as dfet via the debug console. obe works the other does  not.
I am not measuring any voltage as well with the downgraded version.
Next I would try the v2.9 then, and also try the reset.
you mentioned different batteryview versions earlier, which should I use and can it be downloaded here?
what has to be done to do the reset in batteryview properly?
Edited by nibbler79
Your SOC is showing as 39%. Not sure what 'socic' actually is.
To fully reset your battery Turn off, turn back on then hold down red ‘SW button’ for five seconds.
This will fully restart your battery module and should resolve any faults.
I've never tried issuing commands to the battery as your really have to know what you are doing.
The last battery view I last heard of was 3.0.33 for the LV batteries but then it may just have been the wording that the version you used was for HV and it may well be ok for LV as well..
One reset I have seen is below, never used it myself;
Did you 'clear EEPROM' when you uploaded the firmware?
i think i did not clear eeprom. should i give that a try?
It may be worth a try.
did change the firmware to 2.9 including a eeprom reset - but same situation as before.
I am reaching out to pylontech support now.
