Switching on an inverter.
Good day. Can you switch on an inverter without any other connections like a inverter out, solar and battery connections to see if it's working and the settings.
Only inverter in connected to a 3 pin plug and switched on.
Thank you
Welcome to the forum.:)
Depending on your inverter, it would be best to startup on battery, and if all is setup and working correctly, switch on mains AC and Solar.
If you are running a grid tied inverter this is not necessary, and working off mains AC is expected.
A current limited power supply is best, but note that if the power switch is on, it will try to start the DC-AC converter, which will likely be too high a power surge for a typical bench power supply.
You  can use a set of 12 V batteries, but use inrush protection to prevent a massive current spike and splat. This is not good for the wiring, connectors, capacitors, and even your eyes.
