December 6, 20241 yr HI All, I have a 8Kw Deye inverter with 3 LBSA batteries, my max charge is set to 100Amp, this was working but at some stage my batteries only started charging at Max 50Amp. Is this normal or am I missing something?
December 6, 20241 yr 4 hours ago, JacoG said: HI All, I have a 8Kw Deye inverter with 3 LBSA batteries, my max charge is set to 100Amp, this was working but at some stage my batteries only started charging at Max 50Amp. Is this normal or am I missing something? The BMS inside your batteries may restrict the charge current based on various conditions like state of charge, temperature, or cell balancing. Inverters dynamically adjust the charge current based on the connected battery's communication protocols. Ensure that the batteries are correctly communicating with the inverter.
