No power on Mecer kv5 inverter
Hi all, I am new so please forgive the ignorance where applicable 😂 After installing the inverter, switched power on....nothing no light no sound nothing. Must mention no battery nor PV connected only eskom at AC IN. Is this normal as I did not want to use until I have the rest but just wanted to see if it would turn on. Please advise.
I experienced the same as Mr.A last week when turning on the Axpert 5K for the first time. The Pylon batteries were connected to the inverter, but switched off - bit confusing as my inverter's manual does not state anything about the batteries being connected before switch on, AND the Pylon's say the inverter should be powered on before connecting the batteries... confusing. However, all worked out - switched on the inverter at the panel switch, then the Pylon's, then it all came to life! :)
Edited by HowardB
