February 19, 20251 yr Hi Thank you for taking time to read this! What are the most efficient aircons on the market? I see LG & Samsung both have some new ones with big promises. Samsung https://samsungair.co.za/product/new-samsung-ar9500-2-0-windfree-inverter-midwall-split-aircon/ https://samsungair.co.za/product/new-samsung-ar6500-windfree-inverter-midwall-split-aircon/ https://samsungair.co.za/product/new-samsung-ar8500-windfree-inverter-midwall-split-aircon/ L&G https://www.lg.com/za/residential-air-conditioners/m246kh/ I want to get the following: 12 000 BTU Units x 3 24 000 BTU Units x 1 38 000 BTU x 1 We run the aircons a lot as it's a very hot climate. We run them on the dehumidify setting mainly as it uses less electricity. We also want to do a solar install so it makes sense to get something efficient! What aircons would you recommend?
February 19, 20251 yr You need to install inverter type aircon's. The claimed consumption is exactly what it says claimed. Also check the support and spares availability of the manufacturer.
February 19, 20251 yr I installed 12000btu inverter AC and must say it works great once the room is down to temp it draws around 400w constantly . Low loads will only depend on if the AC is sized right for the room and also if you trying to run freezing cold room .
