March 20, 20251 yr 11 hours ago, ahmad almawal said:Can you help me? I have a device that does not connect to a lithium battery.1st point. Did you check that it works with a leas acid. The display shows that it sees the battery.2 nd point Is the battery not fully charged?3 rd point what are your settings for float, bulk and then what source to use. Grid or solar or both?4 th point. What does the inverter report the current battery voltage?Your picture shows the battery fully charged? Edited March 20, 20251 yr by Scorp007
March 22, 20251 yr Author I programmed the charge and float settings to 8.28.Of course, manual settings
