Glen Bowles
On 2019/03/28 at 8:20 AM, Supertubes said:
Goodwe advises to only use Li-on not lead acid batteries with the  GoodWe 3648-EM 3.6kW Hybrid Inverter.
Comment please.
That's cause a Lithium battery has a BMS that can give the inverter accurate battery capacity, and manage safe shutoff if needed. With a Lead Acid you need a 3rd party monitoring system, which may or may be compatible with the inverter itself.
At the end of the day it helps to guarantee performance
ok i have a Goodwe ES and not EM with lead acids. Maybe they are different but the SOC reported by the inverter is actually very accurate. (comparing it with the BMV-702).
