Introducing Red Solar’s Revolutionary 720W Standard, Flexible & Ultra-Light Solar Panels – A Game-Changer for SA Solar Enthusiasts!
Hey PowerForum community!
We’re beyond excited to unveil Red Solar’s G12 TOPCon standard Bifacial (700-720W) and M10-MBB PERC Flexible (425-430W) (520W) and M10 Topcon Ultra Light (595-450W) solar panels, brought to you by Hunan Red Solar New Energy Science and Technology Co., Ltd. These standard Bifacial, ultra-light, flexible, high-output panels are engineered to redefine solar installations in South Africa, offering unmatched versatility, cost savings, and durability. Whether you’re powering your home, business, or off-grid adventure, these panels are designed to make solar more accessible, efficient, and practical. Let’s dive into why these panels are a must-have for your next project!
Why Flexible Panels? The Cost & Practical Advantages Over Rigid Panels Flexible solar panels, like Red Solar’s 425-430W M10-MBB PERC, 520W M10-MBB PERCoffer a host of advantages over traditional rigid panels, especially when it comes to cost savings and installation flexibility. Here’s a breakdown of why they’re a smarter choice for many applications:
  1. Lower Installation Costs
    • Lightweight Design: At just 7.1 kg / 8.6 kg ±5% (425W/520W model) compared to rigid panels that often weigh 20-30 kg, flexible panels require minimal mounting hardware and structural reinforcements. This reduces the need for expensive racking systems or roof modifications, especially on older or lightweight structures like carports, sheds, or mobile setups (RVs, boats).
    • Simplified Mounting: The flexible polymer material allows these panels to conform to curved or irregular surfaces without heavy frames or drilling. This cuts labor costs by up to 30-50% in some cases, as installers can use adhesive mounts or lightweight brackets, avoiding complex scaffolding or cranes.
    • Fewer Panels Needed: With efficiencies up to 19.34% (425W/520W model) and 23.03% (595W ), you get more power per square meter, reducing the number of panels required and lowering overall system costs.
  2. Walkable and Durable Design
    • Walkability: The 425W/520W flexible panels use high light transmittance flexible polymer material, making them tough enough to withstand foot traffic without cracking (unlike brittle rigid panels). This is a game-changer for applications like boat decks, RV roofs, or temporary setups where maintenance access is needed.
    • Advantage: No need for costly protective walkways or access platforms, saving on installation and maintenance expenses. Plus, it simplifies cleaning and inspections, reducing long-term operational costs.
  3. Theft Resistance
    • Low-Profile Installation: Flexible panels can be adhered directly to surfaces, making them harder to remove compared to rigid panels mounted on elevated racks. Their seamless integration into structures like roofs or vehicles reduces the risk of theft, a growing concern in SA.
    • Advantage: Lower replacement costs and reduced need for expensive anti-theft measures like security bolts or alarms, saving you thousands of rands over the system’s lifetime.
  4. Versatility for Unique Applications
    • Flexible panels bend to fit curved surfaces, making them ideal for non-traditional installations like awnings, greenhouses, or portable solar kits. This adaptability opens up new revenue streams for installers and DIYers catering to niche markets.
    • Advantage: Expands project possibilities without the need for custom rigid panel designs, which are often pricier and less efficient in unconventional setups.
  5. Reduced Transport Costs
    • Flexible panels are thinner (3 mm for the 425W/520W models) and stack more efficiently in shipping containers (700 pcs per 40’HQ container vs. ~400-600 for rigid panels). This lowers freight costs, which is a big win for bulk buyers or installers in SA’s remote areas.
    • Advantage: Reduced logistics expenses translate to lower upfront costs for your solar projects.
The Power of Ultra-Lightweight Panels: Engineering Advantages Red Solar’s M10- TOPCon Ultralight 595 and G12R PERC Ultralight 435-450W panels are engineered with cutting-edge technology to deliver superior performance while keeping weight to a minimum. Here’s why their ultra-lightweight design and engineering stand out:
  1. Ultra-Lightweight Construction
    • 595W Bifacial: Weighs only 21.2 kg ±5% for a 595W output, compared to traditional 595W+ rigid Bifacial panels that can weigh 32.5 kg.
    • 425W/520W Flexible: At 7.1 kg / 8.6KG ±5%, it’s one of the lightest high-output panels on the market, perfect for weight-sensitive applications.
    • Engineering Advantage: The use of ultra-white AR-coated semi-toughened glass (595W model) and flexible polymer material (430W model) reduces weight without compromising structural integrity. This allows installation on structures with low load-bearing capacity, like older roofs or temporary setups, without costly reinforcements.
  2. High Power Density with TOPCon and MBB Technology
    • TOPCon Technology (595W model): Tunnel Oxide Passivated Contact (TOPCon) cells maximize electron capture, boosting efficiency to 23.03% and enabling bifacial power generation (up to 25% additional yield from rear-side reflection).
    • Multi Busbar (MBB) Technology: Both models use MBB to reduce electrical resistance and improve current collection, increasing output and reliability.
    • Engineering Advantage: Higher efficiency means fewer panels are needed to achieve the same power output, reducing material costs and installation time. Bifacial capability leverages reflective surfaces (e.g., white roofs or gravel) for extra energy at no additional cost.
  3. Robust Durability for SA’s Harsh Conditions
    • Static Load Capacity: The 595W model handles 5400Pa front/2400Pa back wind and snow loads, while the 435W/450W model supports 3600Pa/5400Pa front 2400Pa back. Both are tested for extreme temperatures (-40°C to +85°C), perfect for SA’s diverse climates.
    • PID Resistance: Strict encapsulation material selection eliminates Potential Induced Degradation (PID), ensuring consistent performance over decades.
    • Engineering Advantage: The panels’ resilience reduces maintenance and replacement costs, with a 12-year product warranty and 30-year linear power warranty (595W model, 0.40% annual degradation) or 25-year linear power warranty (520W model, ≤1% first-year degradation, 0.45% thereafter).
  4. Streamlined Electrical Design
    • IP68 Junction Box: Both models feature a robust, weatherproof junction box with 3 diodes for enhanced reliability and safety.
    • Customizable Cables: The 595W model offers 4mm² cables (300mm +/-, customizable), while the 435-450W model provides 300mm customizable cables, reducing wiring costs and simplifying integration.
    • Engineering Advantage: Optimized electrical components minimize energy losses and reduce installation complexity, lowering balance-of-system (BoS) costs.
Additional Benefits of Red Solar Panels
  • Eco-Friendly Design: Ultra-thin materials and efficient manufacturing reduce the environmental footprint, aligning with sustainable energy goals.
  • Space Efficiency: High power density (up to 595W in a 2278 x 1134 x 35mm footprint for the 595W model) maximizes energy output in constrained spaces, ideal for urban rooftops or small off-grid setups.
  • Aesthetic Appeal: The 520W/425W model’s frameless, sleek design (available in white or black) blends seamlessly into modern structures, enhancing property value without compromising aesthetics.
  • High ROI: With lower installation, maintenance, and transport costs, combined with high efficiency and durability, these panels offer faster payback periods, especially for commercial and off-grid projects.
Perfect for South African Applications
  • Residential: Ideal for homes with lightweight or curved roofs, reducing installation costs and enabling solar in previously unsuitable locations.
  • Commercial: High-output bifacial panels maximize energy yield for businesses, while flexible panels suit BIPV (Building-Integrated Photovoltaics) projects.
  • Off-Grid & Mobile: Ultra-light panels are perfect for RVs, boats, camping, or remote cabins, offering portable, high-power solutions.
  • Rural Electrification: Lightweight design and easy transport make these panels ideal for powering remote SA communities cost-effectively.
Join the Red Solar Revolution! Red Solar’s flexible and ultra-light panels are backed by IEC TS 62941, ISO9001, ISO14001, and OHSAS18001 certifications, ensuring world-class quality. With 12 years of product warranty and up to 30 years of linear power warranty, you’re investing in a reliable, future-proof solution.PowerForum Exclusive Offer: Order 1 Container or more through PowerForum Store and enjoy special for installers and distributors discounts apply! Contact Wimpie Bronkhorst at +27 67 189 7084 or [email protected] [email protected] for quotes, financing options, or custom installation advice. Visit www.powerforum-store.co.za to learn more.
Let’s power SA’s future together! Share your thoughts, questions, or project ideas below – we’d love to hear how you’re planning to use these innovative panels!
See the youtube link on installation procedure for the flexible Solar panels
E -TOPCon (435-450Lightmm.pdf E-G12 TOPCon 132 Bifacial (700-720) V7.pdf 425W Light.pdf
Edited by Powerforum Store
6 minutes ago, zsde said:
Any indicative pricing yet on these flexible panels?
We are aiming at around R3.8 to R4 per watt really depends on the volume and demand we will have some consignment stock available soon however at the moment MQQ is a Container we also have a 520 Watt Model and smaller down to 180 Watt they all will be the same price per watt .
E-M10 144 Soft Light (520) V2_144dpi_75%.pdf
Hi Guys here is the Ultra Light 595 Watt Red Solar Panel with a weight of 21.2 KG compared to a standard 595 Watt Bi-Facial that weighs 32.5 KG
The Ultra Light panel is 11.3 KG lighter than the Standard panel.
When installing 100 Solar panels the reduction in weight of the panels are significant 1130 KG Less weight on the Structure!
Red Solar Ultra Light 2.0mm (590-595W).pdf
  • Powerforum Store changed the title to Introducing Red Solar’s Revolutionary 720W Standard, Flexible & Ultra-Light Solar Panels – A Game-Changer for SA Solar Enthusiasts!
