April 5, 20197 yr Hi All, Yet another question, I do apologise but maybe it helps others also. So i have been convinced i need a battery monitor, i have some questions though... 1.) can a BVM be connected to an axpert to trigger switiching to grid and back? 2.) if you have a BVM, why the need for an ICC? from what i understand the BVM can potentially solve the issues of SOC and checking that recharge is right and that you switch when batteries hit a certain %? TIA
April 6, 20197 yr 6 hours ago, Dex_ said: 1.) can a BVM be connected to an axpert to trigger switiching to grid and back? Not directly. You need software to send Axpert specific commands to the Axpert. 6 hours ago, Dex_ said: 2.) if you have a BVM, why the need for an ICC? from what i understand the BVM can potentially solve the issues of SOC and checking that recharge is right and that you switch when batteries hit a certain %? I don't use ICC myself, but I believe that it is capable of doing this. Hopefully, some ICC users will confirm.
April 6, 20197 yr 4 hours ago, Dex_ said: Through what would the axpert receive these commands? Through the serial port; that's all the comms it has. Either through the RS232 port (via an RJ-45 connector and the supplied cable), or the USB port if it has one.
