Deye comms with PylonTech
I have a Deye 6kW off-grid inverter and a Pylontech US3000C battery, and I’m struggling to get reliable communication between the two.
According to the manuals:
Pylontech:
- Pin 4 = CAN-H
- Pin 5 = CAN-L
- Pin 6 = CAN-GND
Deye:
- Pin 4 = CAN-H
- Pin 5 = CAN-L
- Pin 6 = BMS-GND / RS485-GND
So on paper, the pinouts seem compatible.
I bought the Greenrich/Pylontech to Sunsynk (Deye) CAN cable from GeeWiz, but that cable only uses pins 4 and 5 (CAN-H and CAN-L) and does not include a ground (pin 6).
From what I understand, CAN communication should theoretically work with just CAN-H and CAN-L, and some Deye documentation also suggests that only pins 4 and 5 are used. However, I’ve also seen cases where adding a ground connection (pin 6) or using a custom cable resolved communication issues completely
My question:
Do I actually need the ground (pin 6) for Deye Pylontech CAN communication, or should pins 4 and 5 be sufficient?
If anyone has a confirmed working cable pinout for this exact setup, I’d really appreciate it.
Edited by TheOracle
2 hours ago, TheOracle said:
Maybe I should just try a cable with GRN. Does anyone know where I can find someone to make me a custom cable in Pretoria East?
Before purchasing another CAN cable, strip a piece of network cable use one wire and back probe your existing cable pin 6 to pin 6 with the extra piece of wire check for continuity and see if it solves your comms problem. Then you could decide to purchase a cable with GND. Try Livestainable in Garsfontein Pta.
Livestainable.co.za
No image preview
3m CAN BMS cable for Solis,sunsynk & Pylontech Lithium ba...
3m Can Bms Cable For Solis,Sunsynk & Pylontech Lithium Batteries
Edited by TaliaB
  • TheOracle changed the title to Deye comms with PylonTech
Livestainable.co.za
No image preview
Thanks for the reply. Do you happen to know if the cable from Livestainable has a GND wire?
Not sure but that said. I spoke to my brother in Gauteng and he installed a Deye 5kw with a Pylontech US3000C and this is the pinpouts he used with a cable made up by a pc technician.
Deye 5kw. Pylontech US3000C
Inverter 2 -> Pylontech 6
Inverter 4 -> Pylontech 4
Inverter 5 -> Pylontech 5
I have made a cable with the pins as suggested by you, brother, but it is not working. I tested the cable with a cable tester to be sure.
The Deye battery type is set to Lithium and the Lithium mode is set to 0
Anything else I should check?
