May 7May 7 The Solis S6 80-125kW Hybrid: The "4-in-1" Powerhouse for South African C&IStreamline your commercial installations with the new S6-EH3P(80-125)K-NV-YD-H series.This isn't just an inverter; it is an integrated energy hub that combines PCS, PV, EMS, and STS functionality into a single, high-performance unit.Why it’s a game-changer for your projects:High-Power Compatibility: 10 MPPTs with up to 20A string current, making it fully compatible with the latest high-efficiency, large-format modules.Superior Backup Capability: <10ms seamless switching and 1.6x backup overload capacity for 10 seconds—essential for handling inductive motor starts during load shedding.Flexible Battery Management: Dual independent battery ports supporting 100A+100A charge/discharge, compatible with high-capacity 100–314Ah HV batteries.Intelligent Integration: Dedicated ports for Diesel Generators or Wind inputs, with smart peak shaving in both "Self-Use" and "Generator" modes.Reliability: Type I & II SPD protection and IP66-rated enclosure for long-term durability in local conditions.Scale your C&I offerings with a solution built for resilience. Full Technical Specs: solisinverters.com/za/S6-C&I-Hybrid
