9 hours ago9 hr Take the guesswork out of configuring parallel systems with the Solis S6-EH1P(3–8)K-L-PLUS Standard Operating Procedure.This comprehensive guide walks installers through the essential steps for successful parallel inverter configuration, including:· System overview· Single-phase parallel mode configuration· Parallel terminal connections· Bluetooth connection and inverter communication· Slave inverter parallel settings· Master inverter parallel settings· Three-phase parallel mode configuration· Communication wiring· Master and slave inverter setup· Enabling parallel synchronization· Parallel DIP switch configurationWhether you're installing a single-phase or three-phase parallel system, this SOP is designed to help streamline commissioning, ensure correct configuration, and support reliable system performance.Download the SOP and ensure your next installation is completed with confidence.For all after-sales and service-related enquiries, please contact our support team at [email protected]Your trusted energy partner, supporting you every step of the way. S6-EH1P(3-8)K-L Parallel setup v1.0-2025.pdf
