20 hours ago20 hr I know the basics of my home inverter.I have a 5Kva mecer paired with a cfe 5100 lithium battery.The inverter has been working fine up until a few days ago.The inverter sees the battery and charges it.But the battery only stays on for 10 min then switches off even though full charged.Please advise what I can try?
14 hours ago14 hr 5 hours ago, saflyfish said:I know the basics of my home inverter.I have a 5Kva mecer paired with a cfe 5100 lithium battery.The inverter has been working fine up until a few days ago.The inverter sees the battery and charges it.But the battery only stays on for 10 min then switches off even though full charged.Please advise what I can try?Have you checked what the battery voltage is when it switches off after 10 min?Do you use user settings to charge the battery or comms?
