May 7, 20197 yr Hi Guys. I have the opprtunity to buy a Victron Multiplus 5kva and Sunny boy sb3000 sma from a system that is being upgraded? It also includes a Sunny boy single phase smart meter, display and home manager included. What would a reasonable price be? Thank you for your assistance in advance.
May 7, 20197 yr Buy the one that will not be a problem if where you live, the Munic decided to enforce SANS and NRS regulations. 🙂
May 8, 20197 yr 21 hours ago, Mars67 said: What would a reasonable price be? I think the question is, what does he want for it? And then, how old is the equipment?
May 8, 20197 yr Buy it before load shedding hits... the price goes up then! A new 5KVA MP-II is around 16k now (it's a bit of a guess... verify it!), and depending on the age of it you want to pay somewhere between 40% and 80% of that, so somewhere between 7k and 13k. I know I'm comparing an original aluminium case Multi with the new MP-II... but I'd say that's the competitor for someone in the market. I can't say about the SunnyBoy.
May 9, 20197 yr Author Thank you for the responses guys. I believe the kit is about 8 years old. Why would one use both the Victron and Sunnyboy in your system?
May 9, 20197 yr 2 hours ago, Mars67 said: Why would one use both the Victron and Sunnyboy in your system? For AC-tied PV. A Victron ESS setup has an energy meter on the input side, and it will attempt to keep that energy meter at zero. This works both ways, so when it sees power being imported it will take power from the batteries to cancel it out BUT... if it sees power being exported (by that sunnyboy) it will import it and charge the batteries. By connecting the PV directly to the AC side, you get more efficient direct consumption during the day. You can also tie the Sunnyboy to the output of the Multi, then it remains on even if the grid fails. The only downside to the Sunnyboy: You can't grid-limit it like you can with a Fronius or an ABB. So it is not a great fit for people with prepaid meters.
May 9, 20197 yr On 2019/05/08 at 8:58 AM, plonkster said: Buy it before load shedding hits... the price goes up then! A new 5KVA MP-II is around 16k now (it's a bit of a guess... verify it!), and depending on the age of it you want to pay somewhere between 40% and 80% of that, so somewhere between 7k and 13k. I know I'm comparing an original aluminium case Multi with the new MP-II... but I'd say that's the competitor for someone in the market. I can't say about the SunnyBoy. 5KVA is around 27K new
May 9, 20197 yr 1 minute ago, PaBz0r said: 5KVA is around 27K new Not for the Multiplus-II. That's 1400 Euro, but locally they sell for a bit less. I compared with the cheaper MP-II model because as a second hand buyer that is the comparison I will be making... I can buy a new one for x, vs your 8-year old model of a similar power level for y.
May 9, 20197 yr 3 hours ago, Mars67 said: I believe the kit is about 8 years old. That probably makes it a series-19 processor too, which is really old and cannot run the modern assistants (such as ESS). Unless this is a 26-series control board (look at the sticked on the control board inside), I would probably not buy it. It might make a good inverter for off-grid use on a farm though.
May 9, 20197 yr 14 minutes ago, plonkster said: Not for the Multiplus-II. That's 1400 Euro, but locally they sell for a bit less. I compared with the cheaper MP-II model because as a second hand buyer that is the comparison I will be making... I can buy a new one for x, vs your 8-year old model of a similar power level for y. Well I hope the price gets more aligned to the Euro, current automation web price list I have states 27999:
May 9, 20197 yr 29 minutes ago, Mars67 said: The chip nr is 1959143.VFD so I take it that it is a Series 19? Yup, that's a 19-series.
May 9, 20197 yr 41 minutes ago, PaBz0r said: Well I hope the price gets more aligned to the Euro, current automation web price list I have states 27999: I had to estimate the price. The Multiplus-II 3KVA usually sells around 13.5k, and costs EUR 1080 or thereabouts. the MP-II 5KVA is therefore 1400/1080 = 30% more, or 17.5k. I see I estimated 16k... no idea how I came up with that. Probably a typo.
