Panel Layout
Whe placing panels on a roof what has to be provided for?
Access to cabeling, cleaning etc?
Does one have to provide sufficient spacing between strings etc
It's generally a good idea to leave enough space for the purposes of servicing whatever might be on the roof, such as solar geysers or air conditioners (on flat roofs). If you have to step on PV modules to get there, you're doing it wrong 🙂
Those panels look pretty close to the edges. The required distance depends on your cyclone zone; it will no doubt be different in South Africa than Australia. For me, it was something like 300 mm. The problem is wind getting under the panels in wild weather, possibly taking part of the roof with the panels if they fly off.
