July 24, 20196 yr I need some help regarding matching an inverter with Li batteries. I intend to purchase the Axpert King 5Kw inverter and want to use it on Pylontech batteries. Is this possible and do I need to change the settings to make it work?
July 24, 20196 yr 25 minutes ago, ZOL said: do I need to change the settings to make it work? Yes. You will have to change some of the Charging Volt and Amp settings to mach the specs on the Pylontechs. This is common throughout the inverter range and the settings to match Pylons with any inverter whether its Goodwe, Victron , Axpert or most well known brands are commonly available.
