RCT 5KVA and Lithium battery settings
9 minutes ago, Derrick said:
dang nabbit, he he he, thanks for the reply, I appreciate it. UPS it will become, he he he.
I don't think that you need to settle for this. I also have a 2015 Axpert and recently (successfully) upgraded the firmware to Coulomb's one (LFP flavor). Am now running the Axpert with Pylons and PV without any problems - together with ICC
1 hour ago, Johan Smit said:
It needs a serial port to connect to PC. Cable came with inverter but to find a pc that still has a serial port that has not been converted to a media port is not easy.
I bought a USB to serial converter from Communica (something like this), which worked perfectly together with the original serial cable and ran the firmware update from my laptop
? You just use a USB to serial adapter. Unless I'm missing something here.
Hi there.
I stumbled over this thread while trying to get a Pylon US2000 to talk to a axpert 5k, same as Johan Smit. I'm using it mainly as a UPS for running PC and router during outage.
i used the link for the 73.00e firmware update and the folder had dsp_LF1_73.00e.hex file in it, but running the update software only lets me use the dsp.hex file. i think i almost bricked the inverter trying to use the LF1 file. i dont see a LFP option in the battery profile, is there some sort of magic sauce needed to get it to work?
thanks in advance
15 hours ago, Wulff said:
I utsed the link for the 73.00e firmware update and the folder had dsp_LF1_73.00e.hex file in it, but running the update software only lets me use the dsp.hex file.
That's how the reflash tool is written, it looks for the fixed name dsp.hex. We provide the zip file with the same contents in dsp.hex as in dsp_LF1_73.00e.hex. You might notice that the two files have the same size.
You select Battery Type (setting 05) as USR, then provide suitable values in settings 02, 26, 27, 29, 12, and 13. I'm away from keyboard at the moment, but there are several posts with the magic numbers for PylonTechs.
@Coulomb Thank you Sir. just hooked up the US2000 with 73.00e firmware. there was a bit of a wobble at the end of the update.( was rather slow at 8 blocks/s) when i tried to switch off, and on, it didn't want to and it became unresponsive. So i tried to update firmware again, which it did, meaning the MCU was still kicking ( there was some swearing involved for motivation).
after some digging on the forum i decided to try these settings for my setup, similar to Mr Johan Smit
out 1 utl
tot 2 10A
InP 3 UPS
SAu 4 SdS
bAt 5 uSr
oLr 6 Lrd
otr 7 trE
out 9 50hz
utL 11 10A
b2u 12 46V
u2b 13 51V
ChG 16 utl
bEP 18 bon
LCd 19 HEP
Llt 20 Lon
ALM 22 Aon
oLb 23 bYE
rEC 25 FEn
AbS 26 51.8V
FLo 27 50.4V
PAr 28 SnG
Cut 29 47.5V
SoL 30 onE
bAL 31 Sbd
AbS 32 Aut
nEC 38 dlS
I do not have solar on my system (for shame, i have 6m^2 of roof space facing north and rest of the house is faving east west at a horrid A frame angle.) so thats why I went with the guess on the settings above.
I will be getting a copy of ICC and try get the pylon cable to interface with ICC (if there is ever stock again).
thanks again.
On 2020/03/07 at 1:28 AM, Wulff said:
Quote
 It sounds like your comms board is marginal. Lots of retrying, and too many retries near the end, so it failed. Good on you for persisting.
Please pardon the formatting below, your table of settings has weird invisible characters in it.
Quote
tot 2 10A
utL 11
10A
Those could go up to 20 A, to charge the battery twice as fast, yet under the 25 A maximum.
Quote
b2u  12 46V
u2b  13 51V
Those are very low. But if you want to run the battery as long as possible in a load shedding situation, and won't be in battery mode unless load shedding, I guess that's OK unless or until you add solar panels.
  • 2 years later...
Good day Johan. You don't perhaps have the name of the company in Jhb who can do the update on the RCT 5KVA, for use of lithium battery.
Thank you.
Cobus
  • 7 months later...
