September 16, 20196 yr Greetings, Will discharging a standby AGM battery by less than 1% then recharging constitute a battery cycle? I'm adding 780Wp solar panels to an Axpert MKS 3K-24 to run a 280W refrigerator and 220W deep freezer continuously off solar during the day. A 0.5hp (375W) water booster pump will also kick-in momentarily and will require battery power to make up for the solar shortfall. Will this momentary "battery assist" count as a battery cycle? Setup: Axpert MKS 3K-24 with 600W 75Vdc MPPT, 2*12V*200Ah Ritar VRLA batteries, 2*390Wp 1s2p Jinko JKM390M-72H 49.3Voc panels and "01 SOL" Solar first setting 01. Comments and suggestions to the above setup are welcome so please fire away.
September 16, 20196 yr 2 hours ago, Kilowatt Power said: Will this momentary "battery assist" count as a battery cycle? 2 hours ago, Kilowatt Power said: Will discharging a standby AGM battery by less than 1% then recharging constitute a battery cycle? Not At All.
