Axpert MKS II 5K Display Help
I have the Axpert MKS II 5K and I can get the display to show PV input in Watts while showing output Voltage, Or Battery Voltage and output power but what I want is PV input power and total output power.
I can already make it carry on displaying what is on the screen, I did that by changing parameter 19.
Thanks in advance
Michael
I'm pretty sure the MKS II screen is identical to the MKS screen, and in that case, you cannot display PV in power and total output power simultaneously, unless there is a firmware which allows this? @Coulomb
Patched firmware for some of the MKS models allows you to independently display an "input" value and an "output" value. Some things like battery voltage can be displayed on either or even both. It is possible to display the combination @Micdemas requested. But there is no patched firmware for the MKS II models.
