January 19, 20206 yr Hi i have a RCT 5kva /5000 w. Inverter green color , I had the batteries connected 8x 100amp h 48 v , but there was no load connect to it , I just connected the power to input to charge the batteries , batteries are charging but the batteries are getting hot , and the power light on the inverter is on plus the green charging light is flashing but my lcd screen switch off please advise what could be problem
January 19, 20206 yr 3 hours ago, Kiranbhowan said: i have a RCT 5kva /5000 w. Inverter green color , I had the batteries connected 8x 100amp h 48 v , but there was no load connect to it , I just connected the power to input to charge the batteries , batteries are charging but the batteries are getting hot , and the power light on the inverter is on plus the green charging light is flashing but my lcd screen switch off please advise what could be problem I assume and hope that your batteries (if they are 12 V modules) are connected 4S2P. It could be da fault of da defaults 🙂 The default for setting 11 (Maximum utility charging current) is (I believe) 30 A (maybe 40 A these days?), and your 200 Ah battery should not be charged at higher than 10-15% of its Ah capacity, i.e. 20-25 A. Since you can't choose 25 A, choose 20 A. Quote my lcd screen switch off please advise what could be problem The default for setting 20 (Backlight control) is LOn according to my oldish manual; perhaps yours is set to LOF, so the backlight turns off after 60 seconds of no button pushing, to save power.
