February 21, 20206 yr Hi all. I have new Coslight Harbin 48V 100Ah batteries. I haven’t connected them yet but I wanted to see if they can switch on. Tried everything but nothing seems to work. Does anyone have experience with these? They are bnew. I’m a noob.
February 21, 20206 yr insert a paperclip or small screwdriver into the hole that displays I/0. That looks like the on / off switch. Edited February 21, 20206 yr by GVC
February 21, 20206 yr Author I have done so but then its not responding at all. Thanks for your response.
June 13, 20206 yr For safety reasons, especially during shipping Coslight employs a different battery switching on mechanism 1) First open the top cover of the battery, you will see the screws around the top cover 2) press the 1/0 hole with a paper clip, or anything that can fit in than hole 3) partially open the cover, take a screw driver and short the neutral terminal? with the positive (I think) (there is a black rubber clip which you have to remove in order to do that. Thats how mine were switched on by the technicians. The batteries will switch on. Edited June 13, 20206 yr by alyusuph
June 14, 20206 yr Author On 2020/06/08 at 8:13 AM, Taurai said: hello,what eventually happened with the batteries I used the method described by Alyusuph
June 16, 20206 yr Author 10 hours ago, alyusuph said: So you managed to start the battery? You will love them, excellent product Yes I did. I am now looking for more of these. Would you recommend a supplier?
June 16, 20206 yr Where are you based? I got mine (Indian made) from AfroCube in Harare, they may direct you to a supplier in South Africa. Let me know if you need their vontacts. By the way, once switched on for the first time, you do not need to open the cover again, you can just use the 1/0 pin hole to switch on and off (a good way to tell you your battery was brand new). Also when connected Slave and Primary) you just need to switch on one of them.
July 4, 20206 yr On 2020/06/16 at 6:39 PM, alyusuph said: Where are you based? I got mine (Indian made) from AfroCube in Harare, they may direct you to a supplier in South Africa. Let me know if you need their vontacts. By the way, once switched on for the first time, you do not need to open the cover again, you can just use the 1/0 pin hole to switch on and off (a good way to tell you your battery was brand new). Also when connected Slave and Primary) you just need to switch on one of them. That’s useful regarding the slave and primary, Alyusuph, thanks, as I noticed they were always “live”. I got mine online and 2nd hand with no paperwork. Can I reset the BMS and is there a default password I can then use for each battery to log into the “Coslink” WiFi?
July 4, 20206 yr Unfortunately paperwork is the biggest problem. Great batteries without much documentation. I have tried to write to them in India but do far no response
October 8, 20214 yr Hello, i do have coslight power, what is messing for me to use? I do not have another michine
January 26, 20224 yr On 2020/07/04 at 2:19 PM, Mark Y-M said: That’s useful regarding the slave and primary, Alyusuph, thanks, as I noticed they were always “live”. I got mine online and 2nd hand with no paperwork. Can I reset the BMS and is there a default password I can then use for each battery to log into the “Coslink” WiFi? My name is Dumisani, lovely this coslight battery it is I am looking for another new or good second hand.
November 28, 20223 yr On 2020/07/04 at 2:19 PM, Mark Y-M said: That’s useful regarding the slave and primary, Alyusuph, thanks, as I noticed they were always “live”. I got mine online and 2nd hand with no paperwork. Can I reset the BMS and is there a default password I can then use for each battery to log into the “Coslink” WiFi? Hie whats the WiFi password for coslight GYFP 48100T and what's the name of the software I can use to monitor the battery....if u have it plz send me
December 8, 20232 yr Good day Herman here. Got the same battery but due to my knowledge of it needs a little more info on how to switch it on. If you can show where to short the negative and live it will be much appreciated.
