March 4, 20206 yr Hi all, I need one of these cables, are they off the shelf or Axpert specific? Tony
March 4, 20206 yr 1 hour ago, Tony Swash said: are they off the shelf or Axpert specific? ? The paralleling cables are completely different to the RS-232 cables. They are both non-standard. But the paralleling cables come with the paralleling boards (I assume it comes in the inverter box if your model is one with a parallel board already installed), and the RS-232 cable (RJ-45 at one end, D9 female at the other) comes in each inverter box. You can make your own RS-232 cable using information in this post. I would not attempt to make my own paralleling cable; those cables carry relatively high-speed CAN and other data, including time critical synchronisation data.
March 4, 20206 yr Author Thanks, I did a pin out check and they are all ok and one to one, as is the OEM cable, so still confused. Will have to get an OEM somewhere.
