3 hours ago, Gman007 said:
Hello I get error 02 manual say its over heating.
This is at night and not even outside. What can i check?
Blow the unit out, dust builds up over time resulting in similar behaviour, clean the filters as well. that normally takes care of the problem.
2 hours ago, Gman007 said:
Where does the filters sits?
Its more like a fine steel mesh, at the bottom where it sucks the air in and on both sides on the top where it vents the air out. those gets blocked.
Do I need to disconnect the inverter to blow out and clean filters?
You can just switch it off, both AC and DC supplies.
EDIT: And if your have the Heat Sink part on top, ensure those are clean as well.
Hello Jaco, thank you. I checked this morning mine don't have filters the vents is just open without a filter on the sides, I will also just check if all the fans is running fine.
How can I check the firmware? and is there newer firmware out?
Did you blow it out?.
