Jannas Posted April 18, 2020 Share Posted April 18, 2020 I have a solar system with 18 x 300W panels 2 x 5000w axpert inverters and 1 x 6.2 kw/h lithium ion battery, is there a possibilty to link a 5000w wind turbine on the system,? Quote Link to comment Share on other sites More sharing options...
Coulomb Posted April 18, 2020 Share Posted April 18, 2020 9 hours ago, Jannas said: is there a possibilty to link a 5000w wind turbine on the system,? I believe so. You'll need a separate wind power MPPT that connects directly to the battery. You might have to juggle the battery voltage parameters a bit so that the Axperts can get to float stage properly. Often that means setting the external MPPT battery settings (absorb/bulk/CV and float) to a little lower than the Axperts' equivalent settings. Quote Link to comment Share on other sites More sharing options...
Boon Posted September 26, 2022 Share Posted September 26, 2022 Where do I get a full wiring diagram for 2xaxpert inverters in parallel each with pv string 400ah battery bank and a 3kw wind turbine to be added please help Quote Link to comment Share on other sites More sharing options...
RikusW Posted September 29, 2022 Share Posted September 29, 2022 On 2022/09/26 at 6:43 PM, Boon said: Where do I get a full wiring diagram for 2xaxpert inverters in parallel each with pv string 400ah battery bank and a 3kw wind turbine to be added please help The Axpert diagrams come with the user manuals. Quote Link to comment Share on other sites More sharing options...
Coulomb Posted September 30, 2022 Share Posted September 30, 2022 8 hours ago, RikusW said: The Axpert diagrams come with the user manuals. Not for wind turbines, I think. My understanding is that the separate wind turbine controller would connect directly to the battery, and it would manage charging the battery via wind. The Axpert inverters would manage charging via their PV panels. RikusW 1 Quote Link to comment Share on other sites More sharing options...
