June 7, 20206 yr hi Guys any good software other than solarman to monitor sunsynk 8k and pylontech combo? something like icc or anything that has simple dashboards. regards Pieter
June 8, 20206 yr Hi Pieter Johan from ICC to my knowledge is working on the protocal for Sunsynk monitoring. Give them a call. BMS software for Pylontechs is built into the inverter. Edited June 8, 20206 yr by Halcyon
June 12, 20206 yr @Pieter007 did you manage to find out whether ICC supports Sunsynk monitoring? I was also wondering about this.
June 13, 20206 yr You need to send your logger and inverter serial number to Sunsynk to request update. I suggest you go to Sunsynk website and send your details to the customer care e-mail address. Or ask your inverter supplier. Most of them are on wechat/whataspp groups with the factory/technical and they can request your download. The factory pushes download to your inverter via logger.
March 11, 20215 yr It's already supported by solar assistant. I know a few users that are using it with SunSynk and Deye inverters. I switched from ICC last year. https://solar-assistant.io/
