July 10, 20206 yr Hi Initially I bought four US 2000 batteries in a cabinet and have now expanded by adding four US 3000's, which are working perfectly. I have now bought a cabinet for the 3000's but the distance between the terminals of the top battery in the bottom cabinet to those of the bottom battery in the top cabinet is more that the length of the connecting cables. However, if I remove the feet of the top cabinet I can get the terminals close enough to connect the batteries if I do it "straight up" rather than diagonally, as per the manual. Will it be OK if I connected my batteries as per the image below?
July 10, 20206 yr 10 minutes ago, [email protected] said: Will it be OK if I connected my batteries as per the image below? That will work just fine. Remember to take the black wire that feeds the fuse from the bottom battery and the orange from the top battery.
July 10, 20206 yr Author Thanks Jaco. I have the black and red cables from the batteries connected at opposite ends. Edited July 10, 20206 yr by [email protected]
