August 5, 20206 yr Good day, Do you think that a 12U outdoor Cabinet will house a Kodak King inverter as well as a Pylontech 20000 battery? This is the cabinet in question. https://scoop.co.za/scoop-12u-450mm-deep-outdoor-cabinet-with-2-fans.html Please let me know. Reason is I want to install the inverter and Pylontech outside.
August 5, 20206 yr You will need to get at least 2x US2000 Pylontech batteries for the King (Might need 3x) Each battery is 10cm think. The interver is 53cm high. The cabinet is 69cm high, so it does seem there will be space for it. You just need to make some brakets to hold the batteries, make sure there is enough ventilation to get rid of the heat and then hope no one steels it. So it can work.
