2x 5KW hybrid inverter parallel
Hi quick question can i use 2x 5KW hybrid inverters from 2 different companies and still connect and run them in parallel,
The one is a "Mecer 5kw hybrid inverter" and the other one is a "Easy Power 5kw hybrid inverter" (Not the king inverters)
they both look exactly the same,
Neither of these is really a hybrid inverter, but that matters little here.
They both need to be the same model (you can't have an Axpert MKS paralleled with even an Axpert MKS II), and they need to be nearly the same firmware version number. You can't even parallel a 58.4 V model with a 64 V model. For some, you can download the firmware and update it yourself, but for others the firmware isn't available. The best way to check for parallel compatibility is by checking the main firmware version numbers. If you haven't bought both machines yet, this is difficult.
You'd want to be very sure that neither inverter is a clone.
Overall, I'd suggest that you don't attempt it. But it's certainly possible.
