August 20, 20206 yr Hey all I'm too lazy to take the fans out of my Axpert King. Anyone have the info for the inverter fans: What is the size? (I think it should be 92mm x 92mm x 25mm) What kind of connector (2, 3 or 4 wire)? What is the maximum fan speed? The quality of the fans they use is absolutely atrocious. It is making death noises and I should probably replace it.
August 20, 20206 yr These fans are apparently a close match, but do cause fan lock error on low rpm https://www.amazon.com/dp/B00KF7MVI2/ref=emc_b_5_t I have ordered 2x to give it a try, my fans are also starting to become noisy.
August 20, 20206 yr Author 1 hour ago, Bloubul7 said: These fans are apparently a close match, but do cause fan lock error on low rpm https://www.amazon.com/dp/B00KF7MVI2/ref=emc_b_5_t I have ordered 2x to give it a try, my fans are also starting to become noisy. I seriously doubt that, simply because those fans are low noise, low RPM variety. When I google the ADDA fan used in the non-king model, it is rated at ~5000RPM on the data sheet. If you put a 1800RPM fan in there, you are gonna have a bad time. EDIT: To add, I realize that CFM is the way to measure, not RPM, but there is a correlation. Edited August 20, 20206 yr by Gnome
