August 25, 20205 yr Can someone shoot me the latest 4xx firmware for the Multiplus 48v/3000 Product ID 2620 Currently running firmware 158, definitely needs an update. I have a mk3 usb cable, so can flash insitu. (its on out of the box settings at the moment).
August 26, 20205 yr 4 hours ago, shanghailoz said: Can someone shoot me the latest 4xx firmware for the Multiplus 48v/3000 Product ID 2620 2620476.vff Just remember you will loose the Config file when you update, so please back it up before you flash the firmware.
August 26, 20205 yr Author Got my unit flashed successfully this morning. Relatively painless, other than having to enter the serial (as i had to dig around for that). I can now flash from the pi or vrm portal in future, which is what I wanted support for. Had to use a MK3 usb cable + a usb-c -> usb adaptor + a windows vm. firmware v158 was too old for their current Mac software. VEFlash - Typo's in the flash software (have notified them again) Working flash - (again, inside a windows VM, as their mac software support is lacking) --- Mac software VictronConnect now working. Typical - Victron - prompts for a newer "older" firmware!
