Ellies 2015 6kw inverter and pylontech
If you can set the charge profile (Voltages) then it would be possible. But I doubt this inverter has that.
The options on the battery list (left side of the image) don't include Lithium and also don't match what LiFePO4 can handle.
  • 1 year later...
I have set up this inverter as gel European battery with a dyness 3.5kw lifepo4 and ran for a year . No problems as the BMS took care of the charge and discharge .
